Damnit I have to ask for help again
Was running the SMP client under VMWare and successfully turned in around 100 WU on this PC (e6400 4GB RAM running stock everythng) and only had maybe 2 EUE. Switched it over to the Windows native client so I could get the benefit of having it release cycles for when I am doing something else (VMWare made things just a tad sluggish
I dont think I have successfully turned in a WU yet. The client craps out, EUEs, stops folding at all, you name it, it does it. It successfully borks itself in every way imaginable. I literally have to ctrl-c it about 5 times a day and restart it (to the point that I keep the dos window and the SMP folder open all the time so I can ctrl-c and rerun fah.exe easier)
I am assuming that the machine is stable as it has no problem at all running inside VMWare. This may be silly but I would think with the additional overhead of VMWare this really should allow me to guess that the machine is stable enough for the client.
I have it installed into c:\foldsmp, ran the install and had MPI install twice successfully (or whatever it is that installs twice) I click on fah.exe, fill in the info, do NOT run as a service, have large WU turned on and everything else is the default. This is running under WinXP Pro SP2. I use the EXACT same configuration on the dual quad core xeon server I set up at work last week and it is merrily chugging right along with no issues at all but on this machine it craps out constantly. When it blows up it still shows as running in DOS (no errors except for EUE when it is actually running) but with 0% CPU usage until I stop it with ctrl-c and restart it. It then restarts, gives no errors and finishes another 15% (or 3% or 27% or whatever) and then stops again or EUE. When it EUE it goes right ahead and downloads another chunk and starts folding that until it decides to bork itself again. This is frustrating the hell out of me. If I have to I will go back to the VMWare option until they get the bugs worked out (and am going out of town for 4 days the rest of this week so I will run the VMWare version simply because I wont be here to restart the windows version) but I really would prefer to run this natively as I get work not done faster this way.
Any ideas? I can email you the log if you want to see it.
