dIsRuPtIvE
- Dec 29, 2001
Well I have till Monday before I RMA my mobo so I figure I might post my problem here 1st and see if anyone has any insight.
Ok I've just upgraded my rig with the following parts:
Enermax 24pin 550Watt EG651P-VE
Koolance Exos Al
Athlon 64 3500+ (90nm)
nF4 Ultra-D
X800 XL
NOTE: I always turn my PSU completely off when connecting/disconnecting anything.
I seated the waterblock (CPU-300-H06) with AS5, using the new method by applying 1.5 rice grains worth and spreading with a 1 degree turn in both directions.
I then hooked up the Exos; easy as ever.
After jump starting the PSU and filtering the air from the Exos for approximately 10 minutes, I powered down and hooked up the HDD, Floppy, memory, and DVD.
Everything seems to fire up normally.
All fans run normally.
I get 4 lights and no less. DRAM and standby leds are all lit. I enabled the speaker but get no error code.
The Exos reads a steady temp of 73 degrees Fahrenheit
What I've tried:
I checked RAM seating and moved one stick to the 3rd slot from the 2nd
Cleared CMOS
jumpered for "safe boot"
attempted booting with all drives disconnected
Booting with my USB mouse disconnected as I read people had problems with USB
Only using 1 stick of RAM in the second slot.
Now the memory is in the 2nd and 4th slots
Any help is greatly appreciated.
Koolance Exos Al
nF4 Ultra-D
X800 XL
What I've tried:
Cleared CMOS
