Hey all, friend turned me on to Ultimatedefrag instead of using the normal windows one. It looks like its a really in depth program.
I was wondering which is the correct setting to use to defrag? Would you mind sharing alittle light on which options you take and why?
I found some info on the web about, but really doesnt go into detail, or recommend settings.
