Do you guys think this works with AMD systems, too?![]()
Not if its at default auto-voltage.I noticed they omitted the step where you pump tons of extra voltage into their chip![]()
It will only give a crude OC with higher temps. To get a proper OC and lower temps you have to fiddle with vcore and get it as low as you can for your target OC. And for that extra 100-200 mhz, you may have to fiddle with other settings, ie, QPI/VTT, PLL, etc. Then you may want to decide what sort of overclock you want, ie, just straight out fixed speed (ie, 4.5ghz running 100% of the time) or with speed-step to auto down-clock when not stressed. Or a lower overall speed but with higher turbo and and what cores/percentages you want to assign the turbo values. So a bit more involved to get the optimum OC to suit your needs.
