Uh oh... help me save my data!
Viper87227
It would appear one of my hard drives decided to go the way of the warrior today. For some reason, it completly vainished from existance. No matter how hard I try, windows wont see it. It shows up when I first boot my computer, but windows wants nothing to do with it. Best I can summise, its dead.
Thats only supported by the fact that just two days ago, I had to temporarly copy most of my flac files onto this drive, and then when I copied them all back to the source location, they were all corrupt. I had never even thought for a second the drive could be going bad, I figured some rouge program ate all the files (I had been working with them trying to transcode them to ALAC).
Well, now I am wishing I read the signs a little better. I have quite a bit of data I would like to get off that drive. If anyone knows any way I coudl get the drive working again, just for a short while, I would really appriciate the help.
The drive is a 250GB Hitache Deskstar btw.
EDIT: Well, I did get it back. I am curious though... i removed the drive to get the serial number, and then put it back...thats all I did. Could it somehow be cable related? Could that corrupt data being copied onto the drive.
you may want to consider that your partition on that drive may be having problems
I don't know the technical term, but the best I can describe it is that the partition crashed. I have had this happen several times. the most recent time was 3 hours after I decided to start backing up my data (i delayed it till later that evening, as one of my last tasks of the day and lost it all!)
