So I was planning to overclock, and I did successfully. Then I tried further. Went to 350 mhz bus, (350 * 7). I then changed the DRAM speed from 400 or something I believe, to 800, which is what my RAM is (DDR2 800). I then saved settings and rebooted, and nothing showed up on the monitor. All the fans spun, including the video card. The keyboard lights wouldn't turn on either, nor the mouse optical red light.
What should I do? I don't think its a video card problem, since the video card fan spins, and also since the keyboard and mouse lights don't light up. Maybe it's a RAM issue?
My specs are:
E6300
Foxconn 945P7AA-8EKRS2 Socket T (LGA 775) Intel 945P ATX Intel Motherboard
G.Skill DDR2 800 1g ram
WD 250g HD
eVGA GeForce 7900GS
I also want to try resetting the CMOS on the mobo, but I have no idea how to do it on this one.
Thanks in advance,
Skizzy
My specs are:
E6300
WD 250g HD
eVGA GeForce 7900GS
Thanks in advance,
Skizzy
