Ugh, gamestop and Component Wii cables
Direwolf20
I was at gamestop earlier today and noticed some Component Cables for the Wii behind the counter. I got very excited, as this was the FIRST time I had seen them at an actual store. I've called around a few times, but never found a store with them, so eventually gave up and figured I would get them sometime in the future.
Alas, I found out why they were there.
$49.99. Curse you gamestop! :mad: Aren't they like, $30 from the nintendo store? Sheesh!
Those are not the Nintendo brand cables. Those are the "Premium" cables.
Order the cables from the Nintendo web site and you should have them in a week or so. Or get them off eBay and get the React brand cables for about $20-$25 shipped.
I've noticed that Monster has been very, very active these days in producing cables for consoles, so I'm not too surprised.
My sister bought me those GameStop component cables for $50. They are a total rip off. They are MadCatz which is just an ordinary 3rd party company not a premium company like Monster. So I ordered the same cables from MadCatz online for $20. I'll return them to GameStop. Crazy 250% mark up over retail.
They do work good btw.
Just get the cheapest ones. I was suckered into buying $120 Monster HDMI cables for my PS3 after the salesman @ BB talked about worse image quality, signal interference and other issues noticed with the non-premium brands. A few days after using the Monster cables, I ordered the $8 HDMI cable from monoprice just to see if this salesman was full of crap or not. Not to my surprise, there was no discernible difference between the two. Luckily, BB took the cables back and I bought 2 games instead :)
Buying a $120 HDMI cable is like buying a $120 SATA cable.
omg wtf! the moar money you spend on a digital cable means the more electromagnetick shielding and error recovery filtering circuitry within the cable to ensure less blurring and degradation of the digital signal.
it's too bad they don't sell cables that cost $500 because those would be order of magnitudes better than those crappy $50 component cables :(
i have no ideas abt the Wii connections, but im presuming it has a HDMI output?
i don't think so, just component which is already integrated with sound.
right that makes sense since it wont be doing hi-def stuff XD
IcedEmotion said:
$500 for HDMI or component? Try $900 for a power cable - http://www.psaudio.com/products/xstream_power_premier_sc.asp.
There are quite a few crazy high end products out there that are designed to separate 'audiophiles' from their money.
You think that's something?
Check out this $500 knob that goes to a $6800 volume control:
http://www.referenceaudiomods.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=NOB_C37_C
I too had a hard time finding components, I only been able to find component cables for the PS3 monster brand priced at $60, the PS3 brand component cables are $20, do you really think I am going to pony up $60 for cables that aren't HDMI? well I am still searching, I am trying to avoid ordering it online since I am never home for the pickup. There is some things you can spend a little more like a psu but I don't think so for a cable like that.
I had a guy at FutureShop tell me that monster component cables transmit the signal faster meaning there will be less ghosting on our LCD tv. I seriously wanted to punch him in the mouth.
Wow, the amount of bullshit surrounding uber high end cables...and knobs?! That link talks about "improving overall naturalness..." :p I picked up the Madcatz component cables from Gamecrazy for $20 bucks. I had to use and extension for the audio L/R to reach the stereo tho. Either way, it still looks like crap...but damn Wii Sports is fun! :D
does the Wii have optical audio out or anything....for surround sound?
It has Dolby Pro Logic II, which is for all practical purposes just as good as Dolby Digital.
It outputs DPLII over the analog cables included with the system.
No, it uses Dolby Pro Logic II. It will still provide sound to each of the speakers, but uses a matrix to simulate 5.1 surround sound.
i thought dolby PLII sent a 5.1 signal over the stereo cables in an analog fashion, which then a reciever could recompose into a proper signal?
I really dunno...I'm not much of an audiophile. Check out this for a little more info. I think you might be correct about that.
That is correct.
The Wii essentially outputs 5.1 sound via the analog outputs. DPL II is a close approximation of Dolby Digital. Not many people would be able to tell the difference between the two in a gaming environment, even if they knew what to listen for.
To be fair, you can expect to spend more on a component cable than an hdmi one because its analog and therefore the quality of the cable will in fact matter more than it would on a digital hdmi one. That having been said, nintendo has been terrible with availability of these so if you want them you're gonna have to order online, realistically.
Bash them all you want for other things, but sony went the right route this time- reusing last gen's cables which are widely available and cheap, and making the new, high end output completely standard.
That is correct.
I'm no audio expert, but if that's the case, it seems like they don't make as good of use of the other channels as (for example) the 360 and PS3 do. It just feels like it shuffles sound effects around to the back speakers randomly, but it doesn't actually correlate with anything that's actually happening that should be behind or to the sides of you.
More a function of the audio programming than anything else.
