Ugh, Big mistake?
duncandun
So I bought an ASUS M4A77TD (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131603) based on the reviews both on newegg in in general on the interwebs I thought this was a great motherboard for a budget PC i was building.
However, I chose this at the last second and did not fully comprehend something. It is an AM3 motherboard.
I picked up the Phenom II x4 940, which is an am2+ CPU.
How fucked am I? Is it possible to grandfather in a AM2+ into a am3 only board?
PS Recommend me a cheap/decent cooler for this board/cpu:\, Didn't realize I bought an OEM processor either, megafail.
No, it's not going to work. I'd return the CPU personally.
Lol... well, it would never work, due to the fact that AM2+ only have DDR2 controllers, while AM3 have DDR2 and DDR3 controllers.
That said, I would go with the 955, easily overclocked to 3.6-3.8 ghz just by changing the multiplier. It would be better than the 940. The Athlon II x4 aren't half-bad either, at the same clock speeds, the Athlon II x4 only loses by approximately 5-10% to the Phenom II.
The Athlon II x4 aren't half-bad either, at the same clock speeds, the Athlon II x4 only loses by approximately 5-10% to the Phenom II due to the lack of L3 cache.
spruced up
