Tnx
Something else. I have 5 pcs to which I can install the client. All I need to do is put the same name, team and key right?
Don't forget different Machine IDs
Yes, that's precisely how it works.That's only needed if there are multiple clients on the same PC...5 different PCs can all have Machine ID #1
When speaking purely in PPD terms, all Ati cards are relatively poor in folding compared to nVidia for their level of gaming performance capabilities. I am not current with the Ati client or how much production the 4000-series should make, but don't expect a huge amount from any Ati card, unfortunately. Nvidia is the only GPU manufacturer I'd fold on when everything including power consumption is taken into consideration.I'm going to hijack this thread as I have another newbie question. Currently i'm running a PS3 client and a Q6600+ at 3.4Ghz on the cpu client and a 4870 on a GPU client. I hear the 4800 series is pretty brutal folding but I'm still not even pulling in over 4k ppd with both of these machines. Do these numbers look right or is something horribly wrong? I started using the SMP client as I'm keeping the machine on 24/7 now so i expect this will improve but it seems like i should be doing a lot better than I am.
Ok, i'm going to try shutting down the GPU client and see how it goes. With the SMP and GPU clients on right now the GPU is running around 92-95%. If i turn off the SMP it goes a little higher so I'm still not sure if I might be doing a little better with the gpu than without. I'm trying to hit 4k/day to clear the 90k for september and i'm sitting pretty close right now. Sadly both my desktop and laptop are running ATI cards in them so it's pretty sad production. I might try the SMP client on my laptop but it's a mere i3 330M in there. I don't know if it will be able to complete SMP WUs or if heat will be an issue. Right now running the CPU and GPU on it i'm just barely within the tj max of the CPU when the heat hits its abosolute max.
