Uber High-Tech Touch Screen Stove
HardOCP News
[H] News
This high-tech, touch screen stove concept is pretty damn impressive. Yes, if it was ever developed, it would be extremely expensive but the geek bragging rights would be off the charts. Thanks to our very own Earl Keim for the heads up.
So... what parts are you supposed to touch? :D
At least the design puts the touch screen controls in front of and below the burners. I had a GE stove whose touch controls became unresponsive if the oven was on: The vent was just under the heat-sensitive touchpad.
.....Okay yeah, but can it cook my ramen noodles for me and faster?
A semi cool concept, but I see tons of issues with something like that. Plus the name alone just kills it for me........."The William" ...WTH??? :rolleyes:
One problem I foresee is lying down a spoon or something on the stove and then it starts cooking.
Another is the lack of a bottom, can't bake anything...so I would really need 2 stoves?
Yeah the name is pretty lacking for how cool and innovative the concept really is. I like it, but give it a new name. (Not the iStove pls!)
That's pretty cool... I'd like one if I ever have my own house ........ for rich people.
If it were gas, i would be all for that. I am not a fan of cooking with electric though
iStove it is! Lols. =) 'tis the way of the future, iWallet, iClothes, iGlasses, iNapkins, iBurgers, iCars, iSuck (vacuum), etc.
Lay a big flat cast iron grill over that thing, and you can make some bangin' steaks a'la plancha.
This is definitely an interesting concept, I think if done right it can be really useful. Though, I have a feeling that the price will defeat most of its usefulness.
If it were induction done right, you wouldn't have the same losses associated open flames, (i.e. heat leaving the sides under the pot/pans, etc.) so it depends how you go with electric. There are other cooking devices that are still best gas though, pizza ovens, wok ranges, and tandooris.
:D
Most pots and pans greater than 1 year old no longer exhibit a perfectly flat base.So if you would use that cookware, the pot/pan will only be partially heated.
Watch the video. Nothing cooks until you accept the 'touch' of the item that is place on the stovetop. You can cancel anything you don't want to cook.
You would need a separate oven without a stove top. The combined oven and stove is sometimes referred to as a range but you don't have to buy them that way. Conversely, there's nothing that says The William couldn't be incorporated into a range.
I would actually love this. I haven't found much benefit using our more recent gas stove over our former halogen/electric one. (I never heard the end of complaints from my wife about scratches and stains on the glass, though. She seems oblivious to the grunge collecting around the gas elements.)
As long as it included a facility to adjust the 'element' size, it wouldn't be a problem. Otherwise, radiant stoves shouldn't care what shape your pot is.
I HATE glass cooktops. I bought one because I thought it was neat and the in thing. Big mistake.
They are easy to clean, but that's it.
Cooking temperature control is non existent. It's all over the map.
Gas is the only way to go, or at least variable electric coil at the least.
It's not great for cast-iron either, but usable. That's what I use 95% of the time.
I've never understood this argument. The dials are the same. :confused:
Glass cooktops will even tell you how hot the stove top is (that Hot light goes on when 50 C is reached) and the halogen burner that comes with every glass cooktop I ever used actually starts pulsing on and off when it reaches the set heat level as determined by the dial.
Again, watch the video. You're not just setting dials with this design. You set a temperature program with each element (including cooldown, simmer, ...)
Induction cooking doesn't work with aluminum or copper pans = lol and no.
And Glass tops just don't exhibit the same instantaneous cooldown properties of gas...
I was looking at stoves a few months ago and I never understood why a stove+oven combo costs half or even 1/3 as much as only the stove top piece.
Yeah, thats normal now. At my last house I had a stovetop island and an oven built into the cabinets across from it.
If this makes anybody think of a talking oven or electronic toilet 'ie' iTouch toilet, I already patented those.
2 probable reasons, they charge more because they can, and they charge more because you're willing to pay for it that way.
The likelihood, of the drop in stove catching fire and burning down your house is probably greater proportionately to the price increases too. Liability insurance costs money. Sigh...
there are plenty of homes that have the stove and oven separate. So it wouldnt be that uncommon.
The iStove will have one burner for a proprietary pot. It will have no temperature settings, only one button (a power button) and will cook at whatever temperature Apple decides is best for you to cook with all the time.
Temperature control is FAR less about precision(that's up to the chef) than it is about SPEED. When chefs talk temperature control on a burner, they're talking about how quickly they can move the heat up and down. Glass, as an insulator, obviously impedes this process.
I'd just be for the geek factor.
The designer has no clue about efficiency or cooking i'd say. I think he hung around a LED light panel too long.. I'd be a wiring mess to have all those hex heating elements not to mention even more inefficient electricity wise as you have to use so many little units.
Its just like every other control panel known to man, it controls the flow of electricity or gas. Just it has a lot more of them if ever made. They might as well add an iPAD connector and speakers.
It's a cooktop not an oven, stove is a bad word because it can mean alot of things.
You actually can buy a oven that and a cooktop separately and in most new houses it's how it comes.
Our cook top is separate from our two wall-mounted double ovens.
I would never, ever, have it any other way either.
Not on mine. I get 1-10 as digital settings.
1 is too low, 2 is close to burning up the pots. 3 through 9 are basically useless for anything but boiling water.
Not to mention the cat !
If you have to cook with electric, that's the way to do it! For a range it has a lot of things I like, need a larger kitchen to fit it though since you'd have to have a stand alone oven, and not everyone has the space for that.
Does anyone else think that monitoring weight its a huge game changer? Imagine controlling recipes directly by weight so you know how much water has boiled off or knowing how much you are making so you can follow a diet.
Right now all we have is temperature feedback to control cooking. Couple that with weight feedback and we'll all have even better control of what we eat. Now, add gas sensors to the equation and pretty much everyone becomes a gourmet chef.
While that is a very nifty concept, one issue I see is that "there are over 1050 individual...." parts that can break and probably cost a kings random to fix.
A touchscreen stove? Really? Are women so lazy now that they can't turn knobs? :D
My parents upgraded from their 20 year old washer and dryer to a fancy new set from Sears with all kinds of digital features. The new washer died after less than a year. They never had any issues with the old one.
I like digital stuff, but I don't really see the point of adding complicated digital controls to something if we have more reliable analog controls that work just as well.
I don't think so, i always cook more than i will need so i don't have to cook that one extra night a week. Plates should sense weight, not the cook top
is there anything that we can do about this? We did a working prototype for this and it looks the same...damn it, seems like he just made our document into a clip..thats it...
http://www.ensc.sfu.ca/~whitmore/courses/ensc305/projects/2009.html
name = Thermopix Inc.
Sure, contact Gizmodo since they posted a story about it.
You might also want to somehow get in contact with the maker of the video and see what they have to say about it.
Maybe getting a lawer would be a good idea as well.
Anyody else care to chim in on this?
