- Oct 29, 2000
Hey all,
I'm doing some troubleshooting, and would like to lean on the crowd knowledge of those of you who went Ryzen early.
So, I upgraded my stepson for Christmas from his old FX8350 to a brand spanking new Ryzen 5 1600x. For cooling I used my old Corsair H110i GTX I had kicking around, with Corsairs new bracket for it making it AM4 compatible.
It is configured with two volt modded 3 pin old style Corsair LED fans pulling, and two high powered four pin Noctua Industrial PPC fans pushing, hooked up to the motherboard for fan control. At full load in Prime95 they ramp up to 1800rpm and blast the air through that thing.
Even so, we are still running at stock clocks, and Prime95 runs result in somewhat unsatisfying temperatures. They start at 55C or so for the first group of tests, then slowly creep up at stay in the mid 60's for the later tests. Then when I left it overnight, the CPU was 71C this morning.
Clocks stayed at 3.7Ghz as long as I was watching last night (a couple of hours) up until the low to mid 60C temps. My the morning they seem to ahve throttled ever so slightly at 3.64Ghz across all cores when it was sitting at 71C.
Is running a bit hot just the nature of the beast for these chips, or do I have an issue here? I read there were some temperature reporting issues with Ryzen early on, but that these have now been fixed? Is that accurate? For what it is worth, Ryzen Master, HW Monitor and Corsair Link all report the same temperature.
My next troubleshooting steps are:
- Get new paste and re-mount the cooler. I forgot to buy thermal paste for this build so I had to scrounge through my parts bin in the basement looking for stuff. Found an old tube of Arctic Silver 5, but it may have been 10 years old. Not sure if that makes a difference, but...
- AIO Faults. The pump reports that it is running at 3150rpm though, which seems healthy to me, but each model is different.
Appreciate any thoughts!
Oh, and the obligatory pics of course:
looks like I need to wipe that dust out of the bottom
And the specs:
- AMD Ryzen 5 1600x
- MSI B350 Tomahawk
- 16GB Mushkin DDR4-2400
- Nvidia GeForce Titan 6GB (2013 Kepler version)
- Fractal Design Define S case
- Corsair CX650M PSU
- Corsair H110i GTX AIO Cooler
What started out as a leftoverbut parts bin rig with my old FX8120 from my old server and an old spare 768Mb GTX 460 has upgraded nicely. Last year he inherited my old Titan, and this year a Mobo/CPU/ram/PSU/cooling upgrade.
Kid doesn't know how good he has it to have access to my old parts bin. His rig will never be as excruciatingly obsolete as mine was at his age when I was rocking a 286 in the beginning of the 486 era.
And the specs:
- AMD Ryzen 5 1600x
- MSI B350 Tomahawk
