I'm thinking of picking up another 280X for crossfire and 3x monitor gaming with mining during downtime. I'd be undervolting the GPUs as far as possible while keeping stock core/RAM settings.
Q1: My main question is if my PSU will be enough to handle it. I have a Corsair TX 650 V2. It only has a pair of 6+2 connectors. I'd be running an 6+2 pin PCI-E connector to each card's 8 pin slot, then running an adaptor to each card's 6 pin slot.
Q2: Also, would I want to put each card on it's own molex line for the 6 pin using adaptors, or would I want to plug in a 12v from each line coming out of the PSU to each adaptor (so the cards are sharing both molex lines)?
The case contains:
4xPlatter HDs
1xSSD
2x200mm fans
3x140mm fans
I run the 2500K 4.4GHz @ 1.315v.
The first 280x runs 1000/1500 @1.050v (down from 1.2v stock). I'd be undervolting the second one as well.
I put a Kilawatt on and while mining power consumption is at 360watts at the wall. Stopping mining and prime95ing added 68 watts, so I'm guessing that in my current system total max power draw with CPU and GPU maxed would be 425-430w @ the wall. I'm guessing that my PSU is ~85% efficient at that draw, so the PSU should actually be putting out 365 watts to the system or 30.4amps on the 12v rail if everything is 12v load. The TX 650 is rated at 53 amps 12V.
The case contains:
4xPlatter HDs
1xSSD
2x200mm fans
3x140mm fans
