Two questions on Nforce4
The Saint
OK two questions for thanksgiving :)
1- Should I install the new Nforce 4 drivers for my motherboard? If Yes, then what is the best way to do that?
2- i'm using the Realtek AC97 drivers for the sound on my Asus A8N-SLI, and I would like to give the Nvidia Sound Drivers a try....should I just install them over the Realtek ones? I can't seems to find a way to rrmove them!
1. Download the Nforce drivers from Nvidia.com. It is an exe file. Don't install the IDE driver. If you've already installed some form of the nvidia drivers and you're not having problems...it might not be worth it to upgrade since upgrades have been known to cause problems.
2. Realtek audio drivers are in Add/Remove under Realtek AC'97 Audio. Personally, I'd stick with the realtek drivers.
1- Thank you....I heard that the new version of those drivers is pretty good. I'll think it over and decide if I should upgrade or not.
2- I dont have anything under Add/Remove....no realtek drivers or anything...
Check your device manager and see what drivers are being used for your sound devices.
...From Realtek, most of them are under System32 directory...
maybe it is the Windows compatibilty signed drivers?
I'm downloading an update from Asus for those drivers...reinstalling them.
its all good with the Realtek Drivers... :) Thanks...
now I have to think about the nForce4 drivers...
