As you know I am on the hunt for the maximal size / performance. Found this case http://www.just-cases.com/data/dw66.html (There's a microATX version too btw) . Available here http://www.just-mounts.com/acatalog/WalMount.html .
I bet that PSU is a TFX12V and there are 400W TFX PSUs. Looking at the case, it's hard to imagine how could you make a smaller case with two slots. It's a bit short for a higher end video card but I am fairly sure that can be fixed by a dremel to the front panel
So we have covered physical, power, now on to heat. I am thinking, you know, the Swiftech MCR220 radiator-reservoir-pump is 325mm x 128mm this is already 293mm wide so put that on the top of the case it won't overhang that badly. Add an Apogee LP CPU block, the XSPC Rasa GPU block and you can build a system with as powerful a CPU and GPU that 400W PSU can deliver. Alternatively, use the PSU only for the GPU and power the motherboard with a PicoPSU
Alternaitvely, if you want to be really badly crazy, you can try to squeeze everything inside the microATX version. That's long enough for some video cards -- 9.2 inches. It has space for 4 low profile cards, one taken by the riser. Now, I bet you can squeeze in the space left for the 3 LP card a dual 80mm radiator http://www.frozencpu.com/ex-rad-23.html 82mm wide x 193mm tall x 46mm thick -- I presume the case is tall enough for the 82 mm side. Three cards worth of space might give you that 46mm esp that http://www.just-cases.com/data/inpc_products/dw68/dw68layout.gif suggests a little space between the side and the motherboard (also the case is 66mm longer on this side 'cos of the 3 slots than the ITX w/ the one slot). Obviously you'd want to cut the side out and likely put the 80mm fans kinda outside because there is likely no space inside. I would perhaps use Akasa 80mm x 25mm auto thermal fans. You now have one corner left by the radiator for a small pump and the other corner left by the PSU for a small reservoir... Why would this worth it? Because you end up less than 13l case which is more than the Sugo S05 but using a microATX board which can accomodate a lot, lot more RAM than the ITX motherboards. There are 6, even 8 RAM slot microATX motherboards, the latter being LGA 2011. It'd be interesting to see an i7-3820 and a 6870 in a setup like this... I wonder whether the dual 80mm radiator could dissipate the resulting 200-250W max heat... or whether the http://www.performance-pcs.com/cata...oduct_info&cPath=59_457_336&products_id=23325 dual 92mm radiator would fit instead.
