I'm finally buying a new pc to replace my socket 939, Opteron 185 rig and I'm torn.
I've got $1100 to blow and I was able to put together two different builds which price out almost the same. I primarily use my computer to play WoW. That's about it.
Both builds use an ATI 5850 which is more than enough for my 1680x1050 res.
I upgrade about every four to five years so I want something that will pull it's weight at least that long from a processing perspective, as I can always upgrade the GPU in the future as long as pcie isn't going anywhere for a while.
My decision is tough because I can add a SSD to the E8400 build which could be used for the system partition (Win7 64 Ultimate) greatly enhancing the usability. I would reuse my Raptor150 in the i7-860 build. My data is on a separate RAID setup.
I like the idea of using the current Intel architecture from a future upgrade standpoint but I'm pretty sure Intel is going to keep changing their socket layout yearly (i7-920 anyone) and the E8400 is still a hell of a performer.
Please shoot holes in my logic or make an alternate suggestion.
E8400
http://mcalister.cc/wow/e8400.pdf
i7-860
http://mcalister.cc/wow/i7_860.pdf
I'm not even considering AMD so don't go there =).
Thanks,
Tex
E8400
i7-860
Thanks,
Tex
