I posted this on Head-fi but I want to see what [H] has to say...
I need some guidance and your opinions on my turntable setup.
Listening gear, headphones DT-770 250ohm/Senn 595, Amp Head-Fi EF2A USSR tubes, DAC udac2 (from computer)
Music types, Classic rock(doors, zeppelin, Floyd, eagles), 90's grunge, modern alternative stuff like black keys (very broad)
I have 2 turn tables an Old Technics SL-D2 and a Numark TT200. The Technics has an older AT cartridge from the mid 90's but is still in good shape. The tt200 has a stanton 500v3.
Phono Amp, My budget is up to $130 slightly flexible.
Current preamp is some garage BBE with no gain control and it clips and won't properly ground.
I'm currently looking into this pre amp right here.:
http://www.amazon.com/TC-760LC-BLAC...JFWI/ref=sr_1_9?ie=UTF8&qid=1330959010&sr=8-9
I found it in a search here and seemed liked people liked it, thoughts?
Cartridge, Budget $100
I have heard a lot of good things about Grado and I'm thinking about the Prestige Green , I want good quality, but I don't want a damaging needle as some records are being borrowed. I've heard of the quality/damage trade off but not sure if it's true.
http://www.amazon.com/Grado-Prestig...?s=electronics&ie=UTF8&qid=1330959556&sr=1-10
Turn table accessories. The tt-200 has an optional S tone arm is it worth it to get it?(uses a straight arm right now) Also, are wool mats helpful?
The technics has a lot noise and has a hard time maintaining pitch for a direct drive. For this reason I picked up the numark(it was direct drive and fit into my budget). The last thing I might try to to replace the RCA leads suggestions on those? I have taken it apart and completely cleaned it and also tried the stanton cartridge but the quality wasn't there. Is it worth it to save it anyway?
I'll ask this in here as well, I thought about digitizing the records I own and want to do so at 24 bit 96k. is this a good sound card to do so? http://www.newegg.com/Product/Product.aspx?Item=N82E16829121120
the onboard audio can do it but there is a lot of interference. and I have to use a rca to 3.5 adapter.
