Turn Google Translate Into a Beatbox Machine
HardOCP News
[H] News
[H] reader Izzy Reed says that if you go to Google Translate, set the translator to German to German, paste the text below into the translate box and click the “listen” button you will get a beatbox surprise.
Cut and paste: pv zk pv pv zk pv zk kz zk pv pv pv zk pv zk zk pzk pzk pvzkpkzvpvzk kkkkkk bsch
This did not work for me. I click listen and it does nothing with this "pv zk pv pv zk pv zk kz zk pv pv pv zk pv zk zk pzk pzk pvzkpkzvpvzk kkkkkk bsch" in it whereas if I put actual words it does work?
You don't need to set the second language to anything. It can be whatever. When you press the listen button it outputs what the first language is set as.
edit: just hit the button below the text box instead of the one over next to the "translation"
AND... you can do it in rounds or two different languages if you hit one play button then the other... it will do two outputs at once.
I can't get anything other then english to produce any sound... anyone else?
same here, i couldn't get it to play in either IE 9 or Firefox 3.6.8.
hahhahaha.
Now we need a thread that contains a list of sounds written in letters.
Then, ON WITH THE [H]ARDDJ COMPETITIONS!
