generallee989
- Dec 27, 2011
Hi all,
Thanks again for all the help with the fan/radiator placement questions I had. I finally got the system running. There are a few more things I wall be adding to it in the next week, just couldnt wait and got too excited
This is my question now:
I have only the CPU being cooled right now and Im at 42*C under load.
The tube from the pump going to the waterblock is about 3 feet long spiraling through the case.
Will I get a more efficient cooling with a shorter tube?
Spec:
Intel DP55KG motherboard
i7 870 2.93 CPU OC'd to 3.6
Patriot Sector 5 1600MHz DDR3 x16gb
AMD/MSI HD6950 Reference Board unlocked to HD6970 spec
1000 Watt Antec PSU
Here is the pic of my system:
Spec:
1000 Watt Antec PSU
