- Sep 2, 2004
Hey guys,
Probably have been similar threads in the past, but I didn't see any in recent history.
I've been trying to push my i7 920 (C0/C1 stepping, got one when it first came out) to the 4 GHz mark. I'd had it running stable at 3.8 GHz for a long time, with 1.35 VCore, and just recently I've decided to try to hit 4 GHz. I managed to push it up to 3.9 GHz with no additional changes, but when I tried 4 GHz (200 FSB x 20) the computer booted fine, loaded into Windows, but when I started running Prime95, about 2 minutes later the computer locked up and then BSOD. Before that, there were no issues with temps (all cores hover around 65-70C at load, using a Vigor Monsoon III), so I'm wondering what the issue is. Could it be related to low VCore? I've read that pushing it beyond 1.365V can be dangerous, so I'm not sure how much more leg room there is to raise it.
All other settings are as follows:
BCLK = 195 (trying to get it up to 200)
VCore = 1.35 V
QPI Voltage = 1.35 V
DRAM Voltage = 1.66V
PLL Voltage = 1.96V (not sure about this one, I think this is what I've got going though)
HT off, Turbo off, C1E disabled, SpeedStep on (has been off for the majority of the life of the proc, but I figured I'd like to have the low-power idle speeds.)
Any ideas? Thanks in advance.
VCore = 1.35 V
