Trying to build a "home server"
dyjohnny
Hello everyone,
At this point i'm trying to locate parts for building a home server let's call it. it will basically be a machine running vmware esxi and a few virtual machine (file server, web server, firewall, test machines)
i'm trying to figure out a good motherboard for this setup. at this moment i'm not going to go into dual cpu, setup, or things that come close to server motherboards. i'd like a desktop motherboard that has following features:
- dual network interface (this is a must, since i can make a DMZ, filter various network, vpn tunnells and so on)
- raid support (preferably raid 10) - i need this because most of my critical data will be on those disks. To some extent it will be used for storing media files (mp3, etc etc), but most of that will like on NAS attached to the box, i guess.
I'd like also a lot of USB ports, for connectivity to whatever i find in the house to hook it up to, but that's not really something to be a problem nowadays.
i'd like it to be stable, i won't be doing OC...i think. i will put a dual core CPU inside, and i'm guessing a E7300 will do just fine for the sort of load i'm planning on giving that box.
sofar i've found this board to suit me:
Gigabyte's - EP45-DS3R
does anyone else have any pro's / cons for this board? any other models with dual network and RAID 10 available as far as you guys know?
thanks for the help.
You'll need a 6 or 8 series dual core CPU as the 7 series doesn't support virtualization technology. If you move up to a quad then you'll need a 6 or 9 series.
