I need this computer to be ultra-portable, I'll be taking it from work to home every day. I'll be using simple programs at work, Word, Excel, etc., at home I primarily play cs1.6 and will want to play sc2 and future games.
my budget is around 800$
3) Where do you live?
Bay Area, CA
i'll need a "lan box" or very portable mini, hopefully 8GB RAM, Quad core
Nothing reused
6) Will you be overclocking?
I dont know what overclocking is so proabbly not
19inch CRT
As soon as i get a config that would work
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
no firewire. and i dont really know the other things.
XP pro 32bit.
Here's my initial setup.
Computer Case :Thermaltake LANBOX Lite VF6000BWS w/ Window Cube Gaming Case
Power Supply Upgrade : 550W Heavy Duty TOUGH Series SATA Power Supply
DDR3 Memory : 8GB (4X2GB) DDR3-1600 PC3-12800 Hyper-X
Processor : AMD Phenom II X4 925 2.8Ghz AM3 Quad Core 6MB Cache
CPU Cooling Fan : Original Factory Cooling Fan and Heatsink
Hard Drive : 500GB Seagate 7200RPM SATA-2 UDMA 300 16MB Cache
Video Card : ATI Radeon HD5770 1GB DDR VGA/DVI/HDMI PCI-Express Video Card
DVD Recorder : Samsung 22X DVD+/-RW
Sound Card : Built-in HD 8-Ch Sound Card
Network Card : Built-in Gigabit LAN
Also I'm thinking i might want like a 40-60GB SSD in addition to the regular HD
ALL YOUR HELP WILL BE HUGELY APPRECIATED!!
Bay Area, CA
Nothing reused
19inch CRT
XP pro 32bit.
