Trying a build - Opinions needed
NumberTwo
I'm going to try my hand at building a PC instead of buying a prefab one. Here's what I have picked out so far.
ASUS P5W DH DELUXE/WIFI-AP LGA 775 Intel 975X ATX Intel Motherboard
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor
EVGA 640-P2-N821-AR GeForce 8800GTS 640MB 320-bit GDDR3 PCI Express x16 HDCP Video Card
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
Creative 70SB046A00000 7.1 Channels 24-bit 192KHz PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
OCZ GameXStream OCZ850GXSSLI ATX12V v2.2 and EPS12V 850Watts Power Supply
Western Digital Caviar SE16 WD5000KS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2MB Cache E-IDE/ATAPI DVD Burner with LightScribe Technology
Thermaltake Armor Series VA8000BWS Black Aluminum / Steel ATX Full Tower Computer Case
Some type of water cooling too.
I do light to moderate gaming and would like to learn how to OC and all that jazz down the road. I may also try for SLI in time. I'm trying to stay within a 2,000.00 budget. I currently have a Dell with a 2.53 P4, 1 gig of Crucial RAM and a 6800 GS CO AGP video card. Again, this is my first attempt at a build and I feel like I know how to speak Greek after reading and reading and reading reviews and so on. Any and all info on this build, or one better for my budget would be appreciated.
TIA
If you'll be trying SLI sometime, you need a different motherboard. Something on the nforce 680i or the new asus also supports x16x16.
http://usa.asus.com/products4.aspx?modelmenu=2&model=1567&l1=3&l2=11&l3=495
Check out these PSUs also, I know they're well reviewed, and can do SLI. I'm just not sure about the OCZ as I haven't really read anything on it...could be good though.
http://www.newegg.com/Product/Product.asp?Item=N82E16817139002
http://www.newegg.com/Product/Product.asp?Item=N82E16817256009
http://www.newegg.com/Product/Product.asp?Item=N82E16817151028
http://www.newegg.com/Product/Product.asp?Item=N82E16817151031
http://www.pcpower.com/products/viewproduct.php?show=S75QB
If you don't want SLI, you've got a nice motherboard picked. The 975x chipset is fine for o/c on an e6600. In that same class, might also want to check Intel's BadAxe2.
Yeah, other than the motherboard/SLI issue, everything else seems fine. I have a similar build and it works great for me.
Thanks for the replies. I just ordered the system but instead of the 500GB HD I bought 2 **Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive** of these instead. $2,040.00 with tax and shipping. Theres about 160.00 in MIR's. I hear Newegg is good with their shipping, returns and MIR's plus they're all over [H] so I went with them. Now to assemble it all when it gets here and hope I dont screw anything up. I dont think SLI is that important to me so I stuck with the MOBO.
