I have a black true 120.. not sure what rev it is but I purchased it before the 1366 came out. When the 1366 came out I purchased http://www.sidewindercomputers.com/thlgboreboxb.html and it is a complete bitch to install.. I was looking @ the thermalright site and I saw the one they use is completely different.
Does anyone know where I can buy the stock 1366 mount? I want to remount mine with the correct mount and im going to setup a push/pull config with 2 fans so if someone wants to recommend 2 fans for that im up for it also
Also on the noise of the fans.. I run my 4870x2 @ 70% manual so as long as it isnt louder then that I dont mind..
