flipflopsnowman
- May 30, 2007
OK, there are 15-20 threads a day here that say "Help fix my .... " or "Is my ..... dead?" I'm just about sick of it. So here's my solution:
Post your ways to check if a part is broken (motherboard, ram, videocard, etc) and I will combine them in this post. Hopefully this will get stickied and a lot of unnecessary threads will become baleeted.
Thanks,
Nate
EDIT: This is the bulk of the post, thanks for all contributions. Credit is given where it is due, hopefully I don't make many mistakes
A few notes:
1) RTFM, RTFM, RTFM and when you're done with that, you're ready to start troubleshooting.
2) Always read the manual and make sure you understand what a part SHOULD be doing.
3) Download means look it up online and follow ALL relevant instructions.
4) Take care of your parts while handling. I know that some idiots put their motherboards on the couch next to their cat or on their 1337 shag rug. If you are handling computer parts, treat them with care.
5) Invest in an anti-static mat.
6) Never remove parts while the PC is running.
7) Remain cool, calm, and collected. It is not the part's fault that some idiot (you or other) FUBARed it.
8) Be gentle with your parts and apply just enough force to do the job. Your gf/wife/crush will not be impressed if you can remove IDE cables faster than anyone.
General Troubleshooting
1) If you are overclocking, set everything back to stock (Thanks Danny Bui)
2) If you have access to another (working) PC, try parts in other machine (Thanks Danny Bui)
3) If you do not, take out all unnecessary parts and begin replacing until you find a problem (Thanks BrandonB)
Diagnosing RAM:
1) Download and run Memtest+ on EACH stick separately for a minimum of 3 hours, 24 is best. (thanks Danny Bui)
Diagnosing Motherboard:
1) Reassemble everything outside of the case to make sure case isn't shorting out Mobo. Make sure to do this on a static free mat. (Thanks Danny Bui)
Diagnosing HDD
1) Download and run Drive Fitness Test. (Thanks Danny Bui)
Diagnosing OC Problems
1) Download and run Prime95 to stress test your system.
Thanks,
Nate
A few notes:
Diagnosing RAM:
Diagnosing HDD
