I've been having an issue for the past couple months with my rig. The computer runs fine until the OS has been running for a while (~ 1-2 days, INCLUDING sleeps), then it'll either completely lock up to the point that I have to disconnect power, or it will constantly freeze for a moment every 15-30 seconds, and it will show the wrong cursor (ie if I mouse over a link, instead of seeing the normal 'hand' cursor, I'll see the 'highlight text' cursor).
All of this persists even after reinstalling windows on a new hard drive, with the other hard drive disconnected.
Temps for the CPU and GPU seem fine, and the problem doesn't necessarily seem linked to CPU/GPU stress.
What should I try? Thanks.
My specs:
Phenom II 965 @ stock 3.4
Galaxy GTX 460 768mb
Asus M4A87TD-USB3
Kingston 4gb HyperX
128gb Samsung 830 SSD (Old HD was a 500gb mechanical drive, but this seems irrelevant)
500w Antec PSU
My specs:
Asus M4A87TD-USB3
Kingston 4gb HyperX
500w Antec PSU
