trouble with a htpc build
Valan
Well before I decide to take some parts back to the shop, I was hoping someone here might be able to give me a suggestion to solve my problem.
I built an HTPC using the Asus M3N78-EM, an AMD 5050e retail, a hauppauge 1800 tuner card, 2GB corsair ram, seagate HD, lg dvd writer, antec 380W power supply (came with the antec nsk2480 case). Pretty much what I've seen recommended often in the HTPC forum here for an inexpensive HTPC.
Things seemed fine but this morning I was getting no video out of the PC. LED's were on, fans spinning, no display. I disconnect it from my HDTV, connect it to a monitor via VGA and still no video.
I opened up the case and everything appeared fine after I turned it back on, cpu fan spinning, case fans spinning, power supply fan spinning, and the motherboard LED was on.
I shutdown and started disconnecting stuff to see if I could get a display. Pulled tuner card, then disconnected drives, pulled ram, but nothing happened after each reboot. Doesn't seem to post, no beeps, nothing. Not sure what else I could try and do.
Any suggestions? All I can guess is some kind of failure on the motherboard but I can't figure out why it would of happened.
Thank you for any help you can give.
Hit up the stickied Basic Troubleshooting Guide on what to do when a PC does not POST.
Clear the CMOS.
Reseat the CPU.
If no beeps with no RAM/vidcard installed, its probably the CPU, mobo, or PSU.
Thanks for the input, I did follow the no post instructions in the sticky. Should have looked up there first.
Unfortunately no luck so far.
Last thing I can do is re-seat the CPU, just have not had a chance to do it yet.
I did get a POST error code. (new case didn't come with a speaker so I connected one from an old computer that was broken apparently, a different speaker and I heard the tones)
1 long, 2 short beeps which seems to indicate a failure of the bios to initialize video. So it appears to be the board currently.
Again thanks for the help and the great resource HardOCP is.
Are you using onboard video? Thats odd... I havent seen an onboard video fail before, hehe. Did you try it with a discrete video card?
