Trouble-shooting home built
pdonket
Hey guys, I'm new to this computer forum, however have been a member at notebookforums.com for over a year now, I know pretty much about computers however have never built one myself. So I was looking for some advice on how I would go about diagnosing a problem if it's not obvious. For example, say I come down one morning and press the power button and nothing happens?
Any advice is greatly appreciated! :cool:
Well if the computer won't turn on, it could be a fried power supply. Without more information, can't really help troubleshoot. You can also swap out parts to see which one has failed.
Well, I'm only making it up right now, but basically unless you have multiple parts, trouble-shooting is difficult it seems. I'm only trying to gather info so that my next computer, if I decide to build, will be something that I know if it has problems, I can easily diagnose the problem and just wanted some tips and tricks :)
tips and tricks on how to troubleshoot? first, figure out the symptoms, then go off that, lol. so in your scenario, if a system didnt turn on, first i'd check the power cable, then do a visual inspection inside, then check the power switch, then the power supply. before swapping the part out, i'd try another power socket on my ups/surge protector/wall. if that didnt fix it, i usually have another psu layin around, so i'd swap that in there. theres also psu testers available for cheap. if you don't have spare parts handy, it will, of course, be harder to diagnose. i'd borrow some friends' parts if they let me, or borrow it from the store (some store without a restocking fee, lol, like fry's). if you're new to all of this, just ask on a forum or call your friend who's an it/computer nerd, lol.
I still consider myself a newb lol, as far as building my own goes of course :p. Also, just asking if parts generally break down within a year in a self built system...because I'm used to buying cheaper quality computers, and they constantly break down (dell). And of course since I don't have other systems I built in the past I can't swap parts, so it would be handy if breakdowns rarely occur.
Also, do the individual companies respond generally well to saying for example "I've swapped out your PSU and now my system works, can we process a replacement"
*sorry for all the build it yourself newbie questions*
We were all newbies at one point. If you buy cheaply made parts, then yes they will break down within a year. Buy great quality parts because they're less likely to break down within a year. If breakdowns do occur, most hardware have one year warranties or longer.
Yes. If you explain to them how you came to the conclusion that their part was faulty, and its an acceptable one, then they'll give you an RMA. Otherwise, they'll tell you what you need to do to get to that step, lol.
Dell's are bad quality? When I worked on-campus, we had a ton of dells in our labs... they rarely broke down, especially within the first couple years. what do you do to your systems? lol.
well mostly I beat them with hammers. lol
I treat my laptop with the most care possible and yet, i just have bad luck with all my dells lol, my recently bought Inspiron 9300 in January 2006 broke down so many times that Dell just replaced it. And previous to that I had a Dimension 8400 that basically got 3 full system remakes due to problems in the system. So I'm really looking to run away from Dells. And by high quality parts I assume that means buying from ASUS or XFX or OCZ etc etc? If I'm naming the wrong companies, then tell me :D
Also, just another question when you get the RMA do you send the part to them first at your expense, or do they send the replacement and then you ship it back in the box it was shipped to you in?
well its a good thing you went with dell then, cuz some noname shop probably wouldnt have even fixed them, lol.
I think every brand has a high quality product line, and every high quality brand has a budget product line, lol. (eg. OCZ Value Series vs OCZ Titanium; AsRock vs Asus; DFI Infinity vs DFI LanParty; etc)... just read more reviews to get familar with brands/product lines. You could also ask for a review of parts you chose from this forum... we love debating over which cpu you should get for your needs :p
As far as RMA's go, some companies will cross-ship (ship the replacement product before receiving the defective product), and if they do, they'll need a CC (either to put a hold on some funds from it, or charge it if they never receive the defective product). Often times, the fee they charge for not receiving defective product is inflated. So I don't usually recommend that route, but sometimes its needed.
