the system in my sig. I could never get it past 3ghz. I have since then replaced all my ram from older revision 2gb xms2 to the 4gigs and went to vista 64bit.
I felt like playing around with overclocking again, just for the headache
well i tried going lower multiplier, nothing. then I was just like for shitzngigles I would lower my ram from 850 to 800 and try to get over 3ghz. even just 8mhz over so from 8x375 to 8x376 and nothing. so I went to a 1:1 ratio, which lowered my ram to below spec speed to 376ddr and it booted. its running fine at a nice 3008mhz. anyways. Im gona try and go higher. but if I accually do a 1:1 at 400x8 with the mem at 400 like it is stock. it wont boot.
any other suggestions?
thanks
thanks
