Dan
- May 23, 2012
I have a brand new Windows 7 Pro PC and I'm trying to map drives from a different Windows 7 Pro PC as well as a NAS. When I simply just map the drives and than reboot the PC the drives are either missing or have a red X through them and need to be clicked on to "activate" them.
To resolve this I tried to run a mapping script every time the computer boots... however I'm getting an error when the script runs and nothing is mapping. When I manually map it or try to connect with \\pc-name\folder it connects fine.
The error usually is "System Error 53 Has Occurred The network path was not found"
An example of the script I'm running is as follows (the timeout is to give the PC time to establish a network connection... it has an SSD and boots quickly):
timeout /t 5
net use a: /delete
net use b: /delete
net use c: /delete
net use a: \\nasbox\Folder
net use b: \\nasbox\Folder 2
net use c: \\win7pro-pc\Folder
net use a: /delete
net use b: /delete
net use c: /delete
