inotocracy said:Too "hacked", 4:3 limitation, and you could get better results with just getting another video card.
inotocracy said:Performance wouldn't be that great spanning at a resolution of 3072 x 768 (or greater) on a single card. Seems somewhat pointless for gaming, would be great for multitasking but then you COULD just get an additional card and have 4 monitors.
jnick said:Not to mention no game developer would include it as these days widescreen POV is considered an "unfair advantage"![]()
BBA said:WTH are you talking about? Multiple cards in the first place are an assumption that it would be for SLI or Crossfire. In the case of SLi, you can't use 4 monitors IF you have SLI enabled.
They would both be fine at that resolution for gaming. The real problem about three monitors in gaming is motion sickness is amplified. (BUT it's good for flight sim use)
Unknown-One said:I wonder, would it be better to use a DualHead2Go and then the 2nd head on your graphics card to get 3 screens, ot one TripleHead2Go![]()
inotocracy said:That raises an interesting theory, the posibility of six screens? Could one top of the line card run two of these, one on each port, spanning 6 monitors? Hm...![]()
Obi_Kwiet said:More immersive. 3x good 19inch LCD's would be heaven.
BBA said:Only problem is accelerating 3D across both outputs...doesn't work at all on ATi and on nvidia you have to do window mode.
Asian Dub Foundation said:if only i have the money to get a bigger desk, another GTX, and 3 20in monitors
revenant said:No shit! this is a cool thing, but we'll need some serious video horse power to run 3000+ X 1000+ resolutions. Maybe dual 7900GTX extreme cards? or Crossfire'd x1900XTX's? even with those you'd not be able to enable AA.. or maybe 2x at best... with games like FEAR which do per pixel shading for all light sources, when you increase the res like that, it increases the pixel numbers dramatically, and you can do the math there...
VulturEMaN said:
griff30 said:I'd rather span four projectors, two above and two below, (quad LCD projectors) for a 2560 * 2048 resolution. That's real HD gaming.
SatinSpiral said:OMFG I'd completely forgotten about projectors! Finally a way to cheaply overcome the resolution limitations of those damned XGA machines! And unlike monitors, you don't have 1inch wide plastic seams between screens!
EDIT:
http://www.pcnation.com/web/details.asp?affid=303&item=G01822
four of these = bigscreen 20x15 goodness for 1.5x the cost of 3007FPW
EDIT EDIT: http://www.pricegrabber.com/search_getprod.php/masterid=998416/qlty=n
four of these and two triplehead2go's =big screen 16x12 for $2900
Shameless Liar said:So basically you can get 6 of these and tho of those TripleHead2Gos and you can have 38400x768 resolution gaming on one video card. WONDERFUL! I'd like to see a wallpaper at that resolution.
needmorecarnitine said:there are lots of games with widescreen settings offered
Russ said:Yea, but afaik source is the only one that increases your FOV. BF2 actually REDUCES your FOV. Others just stretch.
SatinSpiral said:anybody know if oblivion supports these ultrawide resolutions?
That works great for 2D, but what about games? Will the 7800GT render everything and just pass off the finished frames to the 6100 and use it as a 3rd head, or will the 6100 slow down the whole operation?mrbigshot said:both ati and nvidia offer built in video that can be used as a 3rd sceen, the 6100 on mt tforce will do 3rd and my 7800gt will do the other 2.
all the screens will run a the 6100 framerate im afraid!Unknown-One said:That works great for 2D, but what about games? Will the 7800GT render everything and just pass off the finished frames to the 6100 and use it as a 3rd head, or will the 6100 slow down the whole operation?
if those were all flat-screens i'd be impressedVulturEMaN said:forget triple screen
Wow, who at NVIDIA thought that was a good way to handle things?Rash said:all the screens will run a the 6100 framerate im afraid!
I think its just because they are that nasty off-wite color that all computer hardware came in for the longest time.rox1co said:i think CRTs are ugly![]()
