Let me jump into the topic.
Setup: 2000fp(Portrait view) + 3000fpw(Regular view) + 2000fp(Portrait view) (20" + 30" +20" all from our lovely DELL) http://www.geekzone.co.nz/content.asp?contentid=5891
Video Card: Evga 8800gtx + Chaintech P-FX20 256MB Geforce FX5200 (all monitors are hooked up to Digital connector)
Problem: When I played a movie on the 20" monitor then open up World of Warcraft in the 30" monitor. WoW started to lag (it move every 2seconds or so). When I disconnected the 20" from the fx5200 everything is normal and super fast. When I reconnect and enable the 20" from the fx5200 it started to lag again. I've try the vga connector and it still have the same problem.
Drivers: I uninstall all drivers from nvidia, boot up to safe mode and use the Driver Cleaner to remove any left over. Restarted the computer and install the 97.92 for the 8800gtx. After the 97.92 driver is install, I use the cd driver for the fx5200 to install it driver w/out updating the old files to the new (only what is neccessary for the fx5200 to work). After all the reinstalling is done. It still have the same problem.
HELP: I've try all that I can think of to make it work but all have fail. Anybody out there with this setup experince the same problem as I do? The fx5200 card work so I dont' think its the card but I could be wrong. Any help or input is appreciated.
Thank you.
EDIT: I've forgot to mention that the FX-5200 card is a PCI.
Thank you.
