100_Percent_Juice
- Feb 28, 2012
I didn't know if this was the right section to post this problem so feel free to move if I was wrong.
STORY
My computer details are listed in my sig but I will try to explain my problem with the most detail I can. As of 1 hour ago I had a fully functioning computer. SSD boot drive and a 2TB file storage drive. I decided that it would be best to have a RAID 1 setup so I could better protect the files. I purchased an identical 2TB drive and installed it. My computer could see all the drives and everything was cool. I backed up all data on my first 2TB drive because I heard that it would be wiped to setup RAID anyways. Then I started the process of RAID setup.
Technical
Both 2TB drives are plugged into ICH10 SATA ports
SSD is plugged into Marvell SATA 6 port (ports set to AHCI prior to fresh Win7 install)
What I did
1. Entered BIOS
2. Changed ICH10 controller from IDE to RAID
3. F10 Save and Exit
4. CTRL-i enter into RAID settings (could see both 2TB HDD)
5. Created new RAID 1 volume
6. Save and reboot
Problem
After Post, computer states that boot disk failed enter CD-ROM boot disc
I deleted the new raid volume, removed the 2 HDDs, cleared cmos, etc etc etc
I can't get to boot period. HELP!
STORY
Technical
What I did
1. Entered BIOS
6. Save and reboot
Problem
