Looking to replace my dead Athlon X2 250 system.
1) What will you be doing with this PC?
Streaming for LAN and Web, transcoding.
2) What's your budget? $350
3) Which country do you live in? New York
4) What exact parts do you need for that budget?
CPU, Mobo, OS Drive, Memory
5) If reusing any parts, what parts will you be reusing?
Antec case, 450watt Cooler Master, intel pci-e nic.
6) Will you be overclocking? No
7) What is the max resolution of your monitor?
1680x1050, 19"
This weekend
9) What features do you need in a motherboard?
USB, 6 SATA ports.
linux 64bit.
I live near a MicroCenter and the Athlon FX-4100 w/free mobo looks like it will do nicely.
Here is a list I just quickly put together from their weekend ad:
Corsair Vengeance Series 8GB DDR3-1600 $70
Samsung 830 Series F-MZ-7PC064DAM 64GB - $109
Athlon FX-4100 - $110
undecided on motherboard.
1680x1050, 19"
This weekend
USB, 6 SATA ports.
linux 64bit.
