Totally new gaming system, advice please?
superme1
Gaming, minor web-browsing
1,200 USD (give or take)
3) Where do you live?
Virginia
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything: Case, PSU, GPU, CPU, Mobo, RAM, HDD, Monitor, Speakers, Sound card (I have keyboard and mouse covered)
This is my first build, I will not be reusing any parts
6) Will you be overclocking?
For the first time yes, minor OC
Plan on getting Dell S2309W
ASAP, during bing double CB deal
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Good OC ability, easy UI (first build), possibly SLI in future
10) Do you already have a legit and reusable/transferable OS key/license?
Yes
Hello Hardforum, I have a potential Gaming build:
Case: Antec 902 - $132.99 (superbiiz) - 20% CB = $106
PSU: Antec EA650 - $85.99 (superbiiz) - 20%CB = $69
CPU: Phenom II X4 810 BE - $140 (superbiiz) - CB = $112
Mobo:ASUS M4A78T-E $94 After CB+Rebate
GPU: GTX 275 - $210 AR (newegg)
RAM:Corsair Dominator 6GB DDR3 1600 (can this run on my mobo??) - $95
HDD: WD Caviar Black 500GB - $70
Monitor: Dell S2309W - 150$
Speakers: Logitech G51 - $147
Sound card: X-Fi Xtreme Gamer - $81
Total: $1,134 - 10% back on Newegg from Bing = $1057
Any comments on the build? Want it to last maybe 2 generations of video cards if that is realistic but basically last 2 years or so. Thanks for the input guys, im a n00b you're the expert.
That's not a 6GB set. You linked to a 3GB set. I recommend this RAM instead:
$80 - G.Skill F3-12800CL9D-4GBNQ 2 x 2GB DDR3 1600 RAM
That Black 500GB is poorly priced as you can get the larger 750GB drive for only $10 more:
$80 - Western Digital Caviar Black WD750AALS 750GB SATA HDD
Video card, the HD4890 performs about the same as the GTX 275, if not better, but is cheaper even without rebate:
$195 - XFX HD-489A-ZDFC Radeon HD 4890 1GB PCI-E Video Card
Thanks for your speedy response. Of the few posts I've posted, you've responded almost to all of them, thanks a lot.
Well I guess it was wishful thinking to think that 6gb would be under 100 =(, sorry about that mistake. I think I will go for the 750 gb drive, however I don't know about changing video cards. I have read a lot about these two, but I want my first card to be Nvidia, I don't know why, but yea...I might change my mind later, but thanks for the input
No prob.
Yeah there were 6GB sets for under $100 two months ago. Hell I remember seeing one for $80. Unfortunately RAM prices have gone up in the past two months.
