You seriously have absolutely no idea how client-server connections work in videogames, do you? Does your concept of them involve a voodoo witch or a black mage of some kind? Shooting an environment item to test lag is a ridiculous idea if you don't even know whether environment object physics / events are rendered by the server or by the client...and most internet games render them clientside, so congratulations, you're proving precisely nothing except that your computer has a solid loopback connection. To correct some other points in that mass of misinformation that is your post, no, a person pinging 25ms is not 4x faster than somebody pinging 100ms, technically or otherwise, and no, those 1-second-long delays in rendering are not lag, they're packet loss. The concept of leading enemies based on their footsteps has absolutely nothing to do with latency whatsoever, particularly in a game like Counter-Strike (which is what you apparently base your vast body of knowledge off of) where the game's server side calculations deliberately average movements out to decrease serverside bandwidth usage and even out the playing field latencywise...christ, to correct every point you're wrong on I would pretty much have to just re-write your post, so can we just have everything you said stricken from the internet? That would be swell.MrGuvernment said:For me lag is when you say, see someone, then they skip ahead a few feet.
or you fire your gun, and it literally takes 1+ seconds to see it hit something, or you unload a clip into someone and nothing hits them, then they shoot you once and your dead.
And yes, for sure, the lower your ping, the better chance
Someone witha 25ms ping, vs my 100ms is technically 4x faster then i am, which can be the result of me turning a corner, them hearing me, but me not hearinf them until they have shot already knowing i am coming, it happens now and then, this is why often people with higher pings learn to shot just before turning a corner, and then often the dead person screams your a hacker! you wall hack!
When i was in toront and playing cs:s on my uncles cable, with a sub 30ms ping, i played awsome, so the ping can affect ones skill level considerably.
As you stated, many server try to run a game too hard, they dont have the capacity to run say a 32man 100tic server
our squads servers [xXx] have toyed with 100 and 66, we can do a 40man 66 tic no problems, if we go to 100 tic,got to drop it to 32 or less.
i often test lag by blowing up a barrel, or shooting a box that will destruct, if the result is instant - your not lagging.
