To my wit's end
Xodus5
I went to fry's today to get a 20-24 pin adaptor because my PSU(aspire 520w) is a 20 pin and I need a 24 for my new Gigabyte DS3. I but it on there and turned it on, short peeps(power error). I look at the connectors something doesn't seem right. So one by one I unhook the connectors off of the molex connector and when thats done I put them in order and connect them. Still short peeps! I have no clue what to do, any suggestions?
I cringe when I see "Aspire PSU" in print. Then a 20-24 pin adapter on top of it. :eek:
Get yourself a decent PSU.
I also have a DS3 right now, but I came from having DFI boards for a while. DFI boards are very sensitive to bad PSUs, so one gets to find out quick what's what in the world of PSUs running DFI boards.
Check this out:
http://www.dfi-street.com/forum/showthread.php?t=29248&highlight=crappy+psu+list
I have a Fortron AX-500 and it's been fine with all of my DFI boards and now my DS3.
You don't need a 24-pin adapter. I run my a DS3 in my brother's computer with a 20-pin Thermaltake 480W PSU and it runs without any problems.
That being said, if you're rewiring your PSU to get things right, you'd probably be better off with a new one.
Well I got short peeps and no post so that means a power problem according to the manual
reread kirby's post.
you don't need an adapter. just run it on 20 pins. Use the manual to figure out the right way to plug it in.
