mensaphone
- Feb 17, 2008
That is the question.
So, I started out intending to build my next rig...had it pretty much figured out; came out a bit more then I was expecting
Figured I outta check out the big boys/boutique builders. So basically I realized building yourself saves you....nada (or close enough
(Yes I'm aware of the other "benefits" of buliding, but honestly my times at a bit of a premium)
Anyhow, long story short - I don't particularily have any questions yet. Just chronicling my adventures
So I started building my rig via the standard newegg. Just like everyone else.
I then proceeded to check out the commercial big boys:
Dell
HP
Gateway
and now currently looking at the boutique builders: (in no particular order)
Velocity Micro
Maingear
avadirect
Hypersonic
ABS
Puget
vigorgaming - know nothing
Polywell
Alienware
Falcon Northwest
Ones that didn't make the cut:
(mostly for inconsistent reviews..mostly QA and Customer Service)
cyberpower
Monarch - website broken :/
Solaris PC - horrible website
cyberpower - Highly customizable, Excellent (perhaps best) prices, HOWEVER, Questionable CSR/Tech/Warranty support
Voodoo (Too Expensive
ibuypower
I'm leaning torwards a VM or maingear. They seem to have the best ratio of price/value. (which brought me to this site)
..but unlike most, the fact that VM sells in BestBuy actually kinda turns me off :/
The Alienware suprisingly prices out fairly well...but I'm not 18 anymore
I like the Falcon NW and the hypersonic systems alot...but a bit pricey.
I started out at the 1.5k range but have creeped upto 2k (+ a little bit) range. (Post #6 for desired Specs)
Dell
HP
Gateway
Velocity Micro
Maingear
avadirect
Hypersonic
ABS
Puget
Polywell
Alienware
Falcon Northwest
cyberpower
ibuypower
