Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am a gamer and i would like to upgrade my mobo/cpu/ram, i have a brand new watercooling kit i purchase from danger den and would like to o/c my new comp so.
First drop the PC4000 stuff and get PC3200 or PC3500. Be sure and check to find out what brands and chips will run on your board. The MAX3 tends to be a little picky especially around CH-5. Set your divider to 5:4 and keep your timings at least at 2-3-2-5. I would suggest Mushkin PC3200 or PC3500 lvl 1 if others are able to get the CH-5 chips to work find on the MAX3. Otherwise get the Mushkin Special 2-2-2 with BH-6 chips cause i know they will work.
I would also consider uping to a 3.0c instead of a 2.8c cause you'll probably get a higher overclock.
