Hi guys,
I have never built a computer but I'm tired of spending so much money on a pre built one and then it not live up to the hype...so I will try to build my own. So far this is what I have come up with, there are some things im working on though
Motherboard:
GIGABYTE GA-P35-DS3P Rev 2.0 LGA 775 Intel P35 ATX Ultra Durable 2, Ultra Cooling Intel Motherboard - Retail Ultra Durable 2, ultra cooling ($155)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128067
OR
GIGABYTE Intel® P35 + ICH9 Chipset DDR2 1066 ATX GA-P35-DS3L Motherboard Retail ($90)
http://www.zipzoomfly.com/jsp/...&prodlist=pricegrabber
OR
MSI P35 Platinum LGA 775 Intel P35 ATX Intel Motherboard - Retail ($125)
http://www.newegg.com/Product/...x?Item=N82E16813130097
I originally had $155 marked down but I was told I can get a good enough one for cheaper; so the next 2 are my choices. I think I am leaning towards the $125 but any advice is welcome
CPU:
Intel Core 2 Quad Q6600 Quad-Core Processor 2.4GHz, 1066FSB, LGA775, 8MB cache Retail $280 http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80864
Memory:
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail $110 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Video Card:
EVGA 512-P3-N802-A3 GeForce 8800GT Superclocked 512MB 256-bit GDDR3 PCI Express 2.0 HDCP Ready SLI Supported Video Card - Retail $300 http://www.newegg.com/Product/Product.aspx?Item=N82E16814130306
Yeah I really want this Video Card cause it has a good warrenty and the step-up program and comes with crysis. But of course its out of stock on newegg...i dont know how long it will take to get back in stock though if it doesnt take long I would like to wait for this if not I'll have to find another one
Hard Drive:
Western Digital Caviar SE 16 WD5000AAKS 500GB 7200RPM 16MB Cache SATA 3.0Gb/s $104 http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=101259
It was either this one or the Seagate barracuda (5 yr warrenty with seagate it nice too) but this one is cheaper and seems to be good.
CD Drive:
LITE-ON Black 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2MB Cache E-IDE/ATAPI DVD Burner with LightScribe Technology - OEM $31 http://www.newegg.com/Product/Product.aspx?Item=N82E16827106055
Power Supply:
Antec TruePower TRIO 650 650W Power Supply Retail $100 http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=273507
Cooling Fan:
Tuniq Tower 120 P4 & K8 CPU Cooler - Retail $45 http://www.newegg.com/Product/Product.aspx?Item=N82E16835154001
Wireless
INTEL 3945ABG 54Mbps 802.11a/b/g PCI-Express Mini Network Adapter Retail
$23
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=10006854
Case:
LOGISYS Computer Area 51 CS51WBK Black Steel ATX Mid Tower Computer Case 450W Power Supply - Retail
$35
http://www.newegg.com/Product/Product.aspx?Item=N82E16811148030
I will not buy this one...but does anyone have any advice on what the best one to but would be. I would like a cheap one but I will spend a little more than the one i have listed
With the case and the $155 MB it comes to just under $1200...
Any advice you guys can give would help me a ton in buying this...thanks
Motherboard:
OR
OR
CPU:
Memory:
Video Card:
Hard Drive:
CD Drive:
Power Supply:
Cooling Fan:
Wireless
$23
Case:
$35
