Gaming (BF4 mainly). Some photo and video editing.
Would like to do it for $300 including tax/shipping
Green Bay, WI
CPU, RAM, Motherboard
Will list below
6) Will you be overclocking?
Not likely
1920 x 1200 24"
In the next two months (hopefully)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
None in particular,
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No
Current build:
Samsung WriteMaster SH-S203N
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151154
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory Model F2-8000CL5D-4GBPQ
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037
BenQ G2400WD Black 24" 5ms, 2ms(GTG) HDMI Widescreen LCD Monitor 250 cd/m2 DC 4000:1(1000:1)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014173
Radeon HD 7750
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 800 MHz
Memory Clock in MHz 1125 MHz
Also a Corsair HX620W power supply and a 2tb secondary HDD for storage (SATA 3.0)
___________________________________________________________________
Current plan is to replace only the Motherboard, CPU, and RAM.
My ideas:
GIGABYTE GA-970A-D3P AM3+/AM3 AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128627
AMD FX-6300 Vishera 3.5GHz (4.1GHz Turbo) Socket AM3+ 95W Six-Core Desktop Processor FD6300WMHKBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
Mushkin Enhanced Blackline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model 996990
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226189
I'm on a tight budget, and from what I can tell this should be sufficient. I will still need to buy a new OS (Windows), but that I can keep separate for now. It's the hardware I'm worried about. I'm not really concerned over the Intel/AMD thing, as I've used both and been happy with both. I don't need to overclock, though in the future I may dabble a little.
Thoughts?
Green Bay, WI
Will list below
Not likely
1920 x 1200 24"
None in particular,
No
Current build:
Radeon HD 7750
Memory Size 1024 MB
Memory Type GDDR5
My ideas:
Thoughts?
