It's cheap, cool, and small I can't find a reason not to get it?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487025
We still need PhysX cards now? lol
Honestly. Even with a single GTX 780 which I used for some time prior to going SLI 780, I don't think a dedicated physx card is needed. In Batman: AC and Batman: AO you can simply set physx to normal instead of the highest setting and it doesn't seem to impact the framerate in an appreciable manner. Same for borderlands 2. I could see an argument for dedicated physx a few years ago, and the 750ti is a super lightweight card in terms of power use. I suppose it could be used for that, but I really don't feel that it's worth it from a cost/benefit perspective.
Just IMO. I haven't played any recent physx games that didn't run well on the dedicated GPU itself. Of course you may not be able to use the highest physx setting, but 1 notch down will be fine. (at least in the Batman games) OR if you have SLI, you can use the highest setting.
So to be clear, your argument is if you don't use the GPU physx and use CPU only physx that you don't need additional GPU power?
I don't think Batman: AO or Batman: AC allow physx on AMD cards. I bought Batman: AC when I had 7970s and the option was greyed out for physx. (i've obviously moved to NV since then and much prefer nvidia these days)...Anyway, the only exception that I have ever seen to this was Borderlands 2, which apparently allows CPU physx on AMD cards. I'm not aware of any other GPU physx title like this, although I could be wrong. As far as I know....Batman and Physx is a no go on AMD cards. Unless you have a physx card specifically installed with driver hacks.
Now in 2012. Physx definitely did not work on the CPU in Batman: AC with AMD cards. Did that change recently?
Anyway - anyone wondering about it, just give it a shot in Batman: AC with a single GPU 770 or 780. I just tried the highest physx setting in Batman: AC with SLI disabled and it still ran at great framerates. *This* is why I think a dedicated physx card is a waste, but that's just me. Some others may find it of use. What games are you playing with physx, ballathefeared?
I was under the impression that hybrid phsyx used an actual nvidia GPU alongside of a main AMD GPU. Is that what you're referring to? Limitedaccess seemed to hint that AMD cards can use AMD physx. Which is not the case except for Borderlands 2 to my knowledge. Every physx game I ever tried on 7970s (before BL2) didn't allow any type of physx. Granted, I didn't do any driver trickery. AMD drivers alone were a pain in the ass enough, much less dealing with a hack on top of that for physx. So yeah fuck that shit, and i'm glad to be on the green side now as to not deal with AMD's software nonsense. Off topic, i'll stop there.
But I am curious as to anyone else running the Batman games and Borderlands 2 on a single NV GPU. For me they run great with physx on, no additional physx card required. Just my experience.
Planetside 2 had Physx support, and it caused the game to crash constantly, never got fixed, and eventually got patched back out of the game. I haven't heard anything about Physx since. But yeah, the 750 (Ti) does seem like it would be nice for Physx because of the high performance per watt and small footprint.
Dedicated PhysX cards were a thing in the GTX 260 days when PhysX could take up a significant percentage of GPU power, so you would use the 8800GT you upgraded from for a free PhysX boost. These days, your primary card is five times more powerful (ten if you SLI) and PhysX has minimal effect on performance, so there's just no point.
