Thoughts on this build
killianss
Hey guys Just wondering on thoughts of this build. I am a "hardcore gamer" if you will, play everything from sc2 wow crysis 2 anything pc really I game on a 23in 1920x1080 and a 42' 1080p tv for movies and games. And I am coming from an intel core2quad q9300,6gb ddr2 memory 667, geforce gtx 260. 640gb 7.2k sata hd bfg 650 watt psu.
New build goes as follows
Intel Core i5-2500K
MSI P67A-G45 (B3) LGA 1155 Intel P67 SATAhttp://www.newegg.com/Product/Product.aspx?Item=N82E16813130582
Antec TruePower New TP-650 http://www.newegg.com/Product/Product.aspx?Item=N82E16817371021
G.SKILL Ripjaws X Series 4Ghttp://www.newegg.com/Product/Product.aspx?Item=N82E16820231427&cm_re=gskill_ripjaws-_-20-231-427-_-Product
Raidmax Tornado atxhttp://www.newegg.com/Product/Product.aspx?Item=N82E16811156226&
cm_re=raidmax_tornado-_-11-156-226-_-Product
Western Digital 7200 sta 6.0gbhttp://www.newegg.com/Product/Product.aspx?Item=N82E16822136794&cm_re=western_digital_caviar_black-_-22-136-794-_-Product
Also going to go with a gtx 560ti Probably evga.
I am just looking for opinions, I know a skimpped a bit on the case but i think everything else seems like good quality, but if anyone knows a better mobo hd memory or ram at the same price or less then I would definitely be interested in hearing about it. I like most bang for your buck lol
My goal is to get a new build with an OS under 1k.
Thanks for looking!
Intel Core i5-2500K
Thanks for looking!
You picked out two overpriced parts and one low-quality part.
Specifically, the RAM costs about $10 more than what we normally recommend for a 4GB dual-channel DDR3 memory kit. And that 750GB WD Black costs more than a 1TB Samsung F3, yet is no faster than the Samsung in sequential transfers.
The Raidmax case you did skimp on: It has only a single 80mm front fan for intake plus another 80mm fan firing from the left side of the case. Couple those with a single 120mm rear exhaust fan, and you have a potentially poorly balanced case cooling system: The case will act as a dust vacuum while delivering relatively poor cooling.
well if your trying to get a cheap case i think you can still pick up the hec blitz black steel edition i never had any temp problems cpu cooler pulled air from out side of the case same with the gpu's the case works well for under 40 shipped.
1) What will you be doing with this
Gaming Starcraft 2, WoW , Crysis 2, MW2+
1k shipped
3) Where do you live?
upstate ny
4) What exact parts do you need for that budget?
CPU, Mobo, ram, hd,dvd drive,case, psu etc will be building from scratch.
6) Will you be overclocking?
mildly
23in acer 1920x1080p
ASAP
9) What features do you need in a motherboard?Most sandy bridge have all the features I need.
Sata 6 and usb 3.0 are ideal
10) Do you already have a legit and reusable/transferable OS key/license?
Nope, will most likely get a system builders key
I see what you mean about the case and hard drive looks like i will have to switch those out!
Thanks again.
To follow up with E4gle's post:
I recommend this RAM set:
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
Go with the Samsung F3 as E4gle recommended:
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
Cases wise, I recommend these cases:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$80 - Lian Li Lancool PC-K58 ATX Case
$80 - Lian Li Lancool PC-K58W ATX Case
$90 - NZXT Tempest Evo TEVO-001BK ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$106 - Lian Li PC-7B Plus II ATX Case
$110 - Fractal Design Define R3 Black ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
Danny thanks for your input Cooler Master HAF 912 RC-912-KKN1 Looks ideal and will keep me within my budget thats great.
Heres the revised version
COOLER MASTER HAF 912 60.00
Samsumg dvd rw 18.99
Samsung spinpoint f3 64.99
EVGA GTX 560 ti 259.99
CORSAIR Enthusiast Series CMPSU-650TX 89.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 49.99
MSI P67A-G45 (B3) 139.99
I5 2500k 224.00
Win 7 Home premium 99.00
Total shipped 1018.00 or so seems like it should be decent rig. Probably ordering within the next 2 weeks!
EVGA GTX 560 ti 259.999
Hmm, not a good choice for the money since the faster HD 6950 2GB costs $10 more:
$270 - MSI R6950-2PM2D2GD5 Radeon HD 6950 2GB PCI-E Video Card
CORSAIR Enthusiast Series CMPSU-650TX 89.999
Ok choice but this PSU has a better price to performance ration and equal if not higher quality than the Corsair:
$80 - Antec Truepower New TP-650 650W PSU
Again, not a good choice. you won't notice an iota of real world difference between DDR3 1333 and DDR3 1600 RAM. In addition, getting 2x2GB RAM will limit your RAM upgrades to 12GB of RAM rather than 16GB of RAM if you go with the RAM I recommended.
So in other words, no good reason to get that RAM at all.
Ah I see now that ram you recommended is great 1 stick!
Now to iron out the video card and psu.
Basically back in the day I had radeon x800xl and radeon x1950 pro but had problems(overheating) (artifacting etc) with both and since have gone to a 9800gt and gtx 260 and had no problems been great. So that's where I went to the Nvidia route and it seems that the better than the price of a 560ti costs a substantial amount higher. Now the PSU do you think that could handle a gtx 480? im up to 1075 with that card in the basket which is doable but i really cant go higher lol
Thanks again for all the help I appreciate it,
Or if you want an even cheaper Radeon HD 6950: $235
(after mail in rebate)
Ok, my question to you is this: Is the higher reliability, in your experience anyway, worth a significantly lower price to performance ratio?
Either the Corsair or Antec 650W PSU would be enough for a GTX 480? But why look at the GTX 480?
your right the 6950 seems to be the most bang for your buck card out atm. Looks like its time for me to do some research on them :)
Thanks again for all the advice guys, I went ahead and ordered the rig today and I'm hoping to get it all set by the weekend or next week. Changed a few things here and there
Went with the HAF 922 (Figured I would reuse this case later on the line so no need to skimp)
Samsung Spingpoint f31 tb
Antec TP 650
GigabyteGA-P67X-UD3-B3
Gskill RIpJaws
Gigabyte GTX 570
I5 2500k
Win7
Samsung dvd RW
I think this rig will be sufficient for time to come, later down the line ide like to add a cheap card reader and perhaps an aftermarket cooler cpu although I dont think I will be overclocking the i5 very high, just something stable with the stock cooler.
It should be sweet compared to this q9300 and gtx 260 thats aging :)
While the 6950 seems like a solid card, unfortunately I have had trouble with a few ati cards and no problems with my last 2 nvidia (9800gt-gtx 260) So i went with the nvidia route. Also seemed like a good card paired with the gigabyte motherboard.
