M76
- Jun 12, 2012
I recently bought myself this amplified bookshelf speaker set. Here are my two cents of it.
The company claims this is their high end product, and the price reflects that claim very well. I paid about $250 for it. As far as computer speakers go that's quite a lot.
http://www.thonet-vander.com/img/imgprod2/img_prod2_kugel.jpg[/
The amplifier and the power adapter is built into the right speaker box, so there is no external power brick, which is a big plus for me.
The second thing I noticed is that the left speaker cable is very thick it has 4 wires in it, which means the tweeter is driven separately. But unfortunately this cable is also very short. It's barely enough to span my desk from end to end. So if you're looking to put the speakers further away from each other, on a separate stand you're out of luck. I haven't measured it but it's no more than 2-2.5m .And they used proprietary connectors so there is no way to replace it with a longer one, unless you're willing to destroy the one they supplied.
The remote they supply is wired. I'm not a big fan of wired remotes, for this price they could've included an IR remote at least. Also it's only function is to change volume. All other controls are on the back of the right speaker. I might understand that they hide the Tone controls, you usually set it up once and then leave it. But I'd still have preferred them to be easily accessible. But the damn on-off switch is on the back too ?! You use that daily, unless you're a freak who has his computer on 24/7. Why on earth did they think it's a good idea to hide the switch on the back of the speaker? Now I have to fiddle blindly on the back of the speaker each time I want to turn it on/off.
Thankfully I have lots of space to reach the back of the unit, but imagine someone with a cramped desk setup, how will they use it on a daily basis?
It seems to me that they put together this product haphazardly without stopping to even consider ergonomics for a minute.
Oh the remote also has a line in jack connector which I'm also confused about. What good is that? If it was a headphone jack I'd see the use, but a line in?
The design is basic, but stylish. I have no complaints about that.
Sound wise it didn't blow me away. I was expecting something extraordinary. I'm in no way an expert, I don't mean to tell it has bad sound. And it's loud too. I just expected it to blow me away, with the clarity of sound. I hope it will get better as it's broken in. But right now my cheapo Jamo PJ FC-1000 speakers seem to sound better.
Overall I wouldn't recommend this product, for this price there has to be something better out there.
