Thinnest SSD?
milicz
I am looking for a thin SSD for a Lenovo U260, I have read of people having to take the SSD out of its casing to fit it in, I've found it difficult to figure out what the thinnest/fastest/bang per buck SSD would be in this case, has anyone already searched and have an answer for me? FYI, 9.5mm or .37 inch standard thickness is too much creates a bulge).
An intel 320 series will be 7mm tall if you remove the spacer and replace the screws with M2 x 3 wafer head screws. There's a store on ebay that sells laptop screws. Also, I think the Samsung 830 is a 7mm drive also.
