Thinking of upgrading
Rusky
In the near future I want to start upgrading my PC part by part.
Is there anything in the horizon that I should wait for or is this as good as any time to start upgrading.
I have a 2.8 ghz intel
1gig ram
256 meg ATI Radeon 9800XT
Foxconn mobo
Two 10k RPM raptor WD drives in a raid 0
I think I should upgrade my mobo, but which upgrade would give me the biggest increase in gaming performance?
Don't bother upgrading anything. Your system is a bit outdated as it is. It's best to just save up your money and buy a new PC rather than upgrade piecemeal.
hm... now when you say part by part, do you mean several parts at once? becuase you'll need to do the mobo/cpu/ram/vidcard all at once, unless you plan on buying a budget stopgap board like one of the asrock boards and reusing your vidcard and ram. however, if its gaming performance you see, you'll need a new vidcard. what's your budget?
in short, i agree with danny... save up and build a whole new system, but keep the hdds.
I was doing some research yesterday and looks like lots of things have changed.
The socket type for the cpu/mobo the port type for the video card.
I suppose you are correct, I should save up and just get everything at once.
Does anyone have a good suggestion what to do with my old PC? I'm going to transfer over the HDs and maybe ram but everything else will get replaced. Do you suggest trying to sell it on ebay?
You won't even re-use the RAM, because it will be hard to find a matched set for dual channel; don't know about the hard drive but I suspect they too will have to go; give it up; Donate the old PC to a good charity, family or friend.
Check out similar systems and see what they are getting. You can see if you think it is worthwhile for what you might get for it.
