I think I may have found a setup I will go with. I seem to change my mind just about every day, lol. Check it out and see what you think.
Thermaltake SOPRANO VB1000BWS Black Steel/Plastic ATX Mid Tower Computer Case - Retail
Specifications:
Case Type: Mid Tower
Color: Black
Material: 0.8 mm SECC & Plastic
Drive Bays: 5.25" x 4/0, 3.5" x 2/5 (external/internal)
Expansion Slots: 7
Front Ports: 2 x USB 2.0, 1 x IEEE1394, 2 x Audio
Cooling System: 1 x 120mm rear fan, 1 x 120mm front fan, 1 x 90mm side fan
Motherboard Compatibility: Micro ATX (9.6" x 9.6") & ATX (12" x 9.6")
Dimensions: 19.5" x 8.3" x 18.9"
Features: High Efficient ventilation, Tool-Free when installing 5.25" & 3.5" device CF11133145 $78.99 $78.99
DFI LANPARTY UT nF4 Ultra-D Socket 939 NVIDIA nForce4 Ultra ATX AMD Motherboard - Retail
Specifications:
Supported CPU: AMD Athlon 64 processor
Chipset: nForce4 ULTRA
RAM: 4x DIMM Supports DDR266/333/400 Max 4GB
Slots: 2x PCI-E x16, 1x PCI-E x1, 1x PCI-E x4, 2x PCI
Ports: 2x PS/2, 6x USB2.0, 1x RJ45, 2x 1394, Audio Ports
IDE/RAID: 2x ATA 133 up to 4 Devices; RAID 0,1
SATA/RAID: 4x SATA RAID with NVIDIA RAID 0,1
Onboard Audio: Realtek ALC850(8-Ch)
Onboard LAN: Vitesse VSC8201 Gigabit Phy, Marvell 88E8001 Gigabit PCI
Form Factor: ATX CF13136152 $128.00 $128.00
HIS Hightech P-ICE80XN-2I-ZAM Radeon X800XL 256MB GDDR3 PCI-Express x16 Video Card - Retail
Specifications:
Chipset/Core Speed: ATI Radeon X800 XL 432MHz
Memory/Effective Speed: 256MB GDDR3/1000MHz
BUS: PCI-Express x16
Ports: VGA(15-pin D SUB) + DVI + VIVO
Support 3D API: DirectX 9, OpenGL 1.5
RAMDACs: 400MHz
Max Resolution@32bit Color: 2048X1536@85Hz
Retail Box (See pics for details) CF14161132 $299.00 $299.00
ENERMAX Whisper II EG465P-VE FMA(24) ATX12V 460W Power Supply - Retail
Specifications:
Type: ATX +12V
Maximum Power: 460W
Hold-up Time: 17ms at 115VAC or 230VAC, full load
Input Voltage: 95V~135V or 180V~265V (selected by slide switch)
Input Frequency Range: 47Hz~63Hz
Input Current: 60A 115V/230V max. during cold start
Output: +3.3V@35A, +5V@35A, +12V@33A, -12V@1A, +5VSB@2.2A
MTBF: Greater than 100K hours at 70% of full rated load; 230VAC / 50Hz input; 25ºC ambient
Approvals: UL, cUL, TUV, CB, DEMKO , NEMKO , SEMKO, FIMKO
Features: Power includes 24pin, 1x 6pin PCI-E connector CF17103464 $75.49 $75.49
AMD Athlon 64 3200+ Venice Integrated into Chip FSB Socket 939 Processor Model ADA3200BPBOX - Retail
Specifications:
Model: AMD Athlon 64 3200+
Core: Venice
Operating Frequency: 2.0GHz
FSB: Integrated into Chip
Cache: L1/64K+64K; L2/ 512KB
Voltage: 1.5V
Process: 90nm
Socket: Socket 939
Multimedia Instruction: MMX, SSE, SSE2, 3DNOW!, 3DNOW!+
Packaging: Retail Box (Heatsink and Fan included) CF19103535 $190.00 $190.00
2x Crucial Ballistix 512MB 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered System Memory Model BL6464Z402 - Retail
Specifications:
Manufacturer: Crucial
Speed: DDR400(PC3200)
Type: 184-Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2
Support Voltage: 2.8V
Organization: 64M x 64 -Bit
Warranty: Lifetime CF20146546 $85.99 $171.98
NEC Black 1.44MB 3.5" Internal Floppy Drive Windows 98SE/ ME/ 2000/ XP - OEM
Specifications:
Capacity: 1.44/0.72 MByte
Average Access Time: 3ms
Interface: 34 Pin Standard Floppy Connector
Form: 3.5"
Media Type: 3.5" double-side high density, 3.5" double-side density
Features: Maximal performance in minimum space
Packaging: OEM Drive Only CF21152005 $7.99 $7.99
Maxtor DiamondMax 10 6B250R0 250GB 7200 RPM IDE Ultra ATA133 Hard Drive - OEM
Specifications:
Capacity: 250GB
Average Seek Time: 9.0 ms
Buffer: 16MB
Rotational Speed: 7200 RPM
Interface: ATA 133
Features: Maxtor-developed Shock Protection, System (SPS) and Data Protection System (DPS).
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only CF22140153 $127.00 $127.00
Logitech 967502-0403 Black PS/2 Wired Standard Value Keyboard - OEM
Specifications:
Interface: PS/2
Number Of Keys: 104 keys
Design Style: Standard
Features: Soft touch keys, Spill proof design CF23126170 $11.99 $11.99
Logitech MX510 931162-0403 Blue 8 Buttons 1x Wheel USB + PS/2 Optical Mouse - Retail
Specifications:
Interface: USB/ PS2
Number Of Buttons: 8x Buttons + 1x Wheel
Optical/Ball: Optical
Wireless Technology: N/A
Features: Image Processing: 5.8 megapixels/sec; Resolution: 800 dpi; Acceleration: 15g; Speed: 40 inches/sec; Eight pre-programmed button functions; Gaming-tuned software drivers; Quick Switch program selector; Fast Net navigation; High-precision scrolling; Cruise Control scrolling system; Right-hand control grip; Reflex finish CF26104151 $26.99 $26.99
NEC Black IDE DVD Burner Model ND-3520A BK - OEM
Specifications:
Write Speed: 16X DVD+R, 8X DVD+RW, 4X DVD+R DL, 16X DVD-R, 6X DVD-RW, 48X CD-R, 24X CD-RW
Read Speed: 48X CD-ROM, 16X DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
Packaging: OEM (see pictures for details) CF27152035 $48.99 $48.99
SUBTOTAL $1,166.42
SHIPPING AND HANDLING CHARGE*: $ 25.00
TOTAL: $1,191.42
Specifications:
Color: Black
Expansion Slots: 7
Specifications:
Specifications:
RAMDACs: 400MHz
Specifications:
Type: ATX +12V
Maximum Power: 460W
Specifications:
Core: Venice
Voltage: 1.5V
Process: 90nm
Socket: Socket 939
Specifications:
Cas Latency: 2
Specifications:
Form: 3.5"
Specifications:
Capacity: 250GB
Buffer: 16MB
Interface: ATA 133
Specifications:
Interface: PS/2
Specifications:
Interface: USB/ PS2
Specifications:
Buffer: 2MB
SUBTOTAL $1,166.42
TOTAL: $1,191.42
