I was thinking about getting a P5B-Deluxe (non Wifi) as it is probably the best low-cost but high-end Asus mobo I could find. I have a question though. I heard that it has problems with some kind of "Jmicron" controller and that the Gigabyte lan that it uses is horrible.
Now I heard that the workaround for the Jmicron PATA controller was to install some new drivers that came from the CD. But I am using Vista, so I am not sure that these drivers will be compatible? Should I go for the P5W-Deluxe instead or what should I do?
