larrylpaterson
- Jun 27, 2008
I havent built a sys for over six years so you can see iam a behind the curve whats out there what would be a good upper middle bundle to start with the last proc i installed was a 2800 barton .
- What is your budget? Are shipping and/or taxes included within that budget?
- Where do you live? Where are you (planning on) buying everything at?
- Which components do you need to get? Which components do you already have? Which components are you going to reuse (from older builds)?
- What are you going to use your computer for? Which games/programs are you going to use?
- Do you plan on overclocking? Are you going to use water (or some other form of "exotic") cooling?
- Which monitor are you using? What resolution do you use? Are you using multiple monitors? Do you plan on buying a new/multiple monitor(s) any time soon?
- Which features do you want on the motherboard?
- How long do you want this system to last? Are you (planning on) making any incremental upgrades during that time?
upgrades sure
motherboard that just it so many things have changed .
no over clocking
one monitor.
it will be used for some games
not sure on cost thats what iam asking whats out there
