FallenMystic
- Jan 20, 2006
Am I loosing it, (loaded question I know); I'm working on my first water set-up, (read budget,) and I'm finding that the iConnect fittings that come standard with TT products don't exactly seem to be 1/4 ID /3/8 OD... am I just loosen my nut or what?
I've tried going to the hardware store and picking up some extra tubing, (I'm trying a few things different from the 'typical' setup,) and what I come back with, being labeled 1/4 - 3/8, ID/OD respectively and the ID matches up with the barbs as expected, but when trying to slide the nut over the tube it's a no fit, probably about a 1 mm to 2 mm to thick, (the tubing). EEh?!?
Same was found on compression fittings for T-connectors etc...
If I decide to stick with the iConnect stuff am I now locked into using TT Tubing, (or giving other tubing a shave before using it.)
Any help is appreciated,
Fallen Out
Fallen Out
