Hey guys,
In the instructions for the Thermalright XP-120, it shows where to insert the metal clips that hold the 120mm fan in place. This requires the 120mm fan to have holes drilled into the bottom of it. However, Yate Loon 120mm's have this hole but also have a plastic shield extending from the bottom hole to the top hole. Therefore, it's impossible to insert the clips (as there isn't enough length to fit through this "shield").
Any ideas on how to mount the Yate Loon? I'd really like to avoid buying another fan if possible..
Thanks in advance.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance.
